Hello, I've been working on a pretty complex XML file for a VCD I'm making, but now that it's complete, I don't know how to make it into an image. VCDComposer isn't working on my computer, so that won't work. Is there another program? I know that VCDImager's tool "VCDXBUILD" can do it, but I really need step-by-step, over-simplified instructions on how to run the program on the XML file. If I'm not mistaken it will create a cue/bin image... can Easy CD Creator burn that? If not, is there a program to convert a Cue/bin to some other format that it can burn? I'm sorry I've crammed so many questions in here, but I know someone out there knows the answer to all of them. Thank you all for making this such a great site, and thank you to Baldrick for sticking in there to keep the site, and forum alive!
Ben
You do know how to use a command line tool don't you? If not, it's time to learn!
If you type vcdxbuild --help, it will give you a list of all the commands.
For you, the simplest command you can use is:
vcdxbuild myvideocd.xml
And VCDXBUILD will create a CUE/BIN image of your xml file (substitute "myvidecd.xml" for your xml file obviously).
You cannot burn CUE/BIN images with Easy CD Creator. I wrote an article on how to burn CUE/BIN images here: http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
Regards.
Michael Tam
w: Morsels of Evidence -
Vitualis,
You guessed it... I don't know how to use a command line tool. I hope I can figure it out from what you told meIf you (or anyone else) thinks there's anything other tips I should know on using a command line tool, feel free to share! Thanks for the help Michael, I read most of those articles you wrote yesterday, they were a GREAT help. Thanks for taking the time.
Ben -
With command line tools, I strongly suggest that you name your folders simply (it involves less typing).
For example, unzip VCDImager into a directory named "VCD" rather than "VCDImager v0.7.11" or something.
To start the DOS prompt, click on "START" --> Program Files --> MS-DOS Prompt.
You should be faced with:
C:\WINDOWS>
This means that you are in your Windows directory (on the C: drive).
To change directories, you use the cd command (as in "chage directory".
Thus, if you installed VCDImager in the folder C:\VCD you should type:
cd c:\vcd
And you should be in that folder.
Then, run the command I wrote before for vcdxbuild to build your CUE/BIN image.
Regards.
Michael Tam
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 10:50 -
filmindex.xml....WTF?
By ni9ht_5ta1k3r in forum Blu-ray RippingReplies: 8Last Post: 6th Jun 2009, 06:01 -
Megui xml error
By headhunter03 in forum Off topicReplies: 0Last Post: 4th Apr 2009, 09:19 -
srt to xml ? any tools ?
By sat-jokar in forum SubtitleReplies: 3Last Post: 10th Mar 2009, 08:12 -
DriveImage XML
By blockie@sbcglobal.ne in forum ComputerReplies: 2Last Post: 25th Jul 2008, 16:25
