I have some music videos I downloaded that I want to burn onto a dvd-r.
Now I get those common error message when trying to add a file like "incorrect header sequence" and "GOP too long"
I use Tmpg 2.5 to change header :File>MPEG tools> merge and cut, etc.
Now my question is: Is there an easier way? I ask because I have a crap load of videos and am wondering am I going to have to do this with each video? The videos are all mpeg-1.
And another question: Can I just hit "ignore" when it promps? Even when it says the disc might not play on standalone players?
Thanks.
Yes- you can just hit 'ignore'. Of course it may not play in your standalone, so I'd burn to an RW disk to test it.
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 16:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 14:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 10:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 18:59
