  1. What program is best/simplest to use when converting the vob files to an .img?
    Thanks!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
  3. Thanks, but is there a program that allows me to save the .img to my hard drive?
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    Same program, dude(IMGtools).
  5. No, This program is not what I need.
    Here's what I want to do.
    I have a ripped dvd and I saved the vob files on my harddrive, but I'd like to make all those vob files into ONE IMAGE file. So, the vob files will be one filed called movie.img.
    That program does not allow me to do this.
    Any other suggestions?
  6. I'm a Super Moderator johns0's Avatar
    canada
    The program will let you save an image file,under devices choose image recorder.Also tmpgenc dvd author will make iso files which are the same as img files.
  7. Thanks johns0, that's what I needed.
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    it certainly does -- same as using nero to make a iso file or recordnow max ...
