im converting something and it takes a long time for the progress to end what do i do
Results 1 to 10 of 10
Wait.
"Art is making something out of nothing and selling it." - Frank Zappa -
but sometimes when it takes to long it will say writing error is there any way i can speed it up
If you want a sensible answer give people a clue as to what you are trying to do .
What are your computer specs ? That matters greatly when discussing speed.
What are you asking TMPG to do? ie Source and output
Has the writing error suddenly change itself into a streaming error?
You have made 50 posts , it sounds like your first. -
The best way to speed up, and then you get MUCH faster, is to get CCE (cinema craft encoder). Much better quality too, and the lite-version cost like $60. To have a happy life with CCE you should learn some AVISynth scripting, which you can easily learn in less time than it takes to encode with TMGPEnc.
I have tried mainconcepts encoder too, for DV to DVD, its very fast. Anyway, sometimes CCE is faster and in the cases where mainconcept is faster its not worth $90 to save a few seconds.
As for the advice of getting faster pc to make TMPGEnc faster, you would need an enormous piece of hardware for tmpgenc to come close to CCE or MC on an average desktop. TMPGEnc isnt just slow, its annoying and embarassing slow, so slow it hurts just to think about it.
Why do I have multiple files when I convert HD to SD using Tmpgenc??
By Endoking01 in forum Newbie / General discussionsReplies: 12Last Post: 9th Jun 2010, 21:43 -
TMPGenc CAN NOT CONVERT AVI LF RT CHANNELS TO 2 AUDIOS
By suijaypao in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 05:03 -
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 21:02 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 16:53 -
Fastest program to convert avi to dvd is to long
By goheadtry in forum Video ConversionReplies: 12Last Post: 27th Jan 2008, 04:33
