I had a VHS tape a while ago and it was NTSC
I needed to make a backup of it, so I gave it to a video conversion company who recorded the NTSC VHS stuff to PAL DV tape for me.
Now I have this PAL DV tape here and I'm workin with it now in order to make a PAL DVD from it. But I'm worried about the conversion the guys have done. I have the DV video in TMPEG now and I'm coding it over to DVD MPEG2 PAL, but there are some thin lines on the footage visible on the TMPEG preview screen, and I'm pretty sure they have to do with the NTSC to PAL conversion done earlier.
now I dont have the source NTSC VHS available any more, so is it possible to fix these errors now? would it make any sense to convert the footage back to NTSC? thanks for any ideas and help!
Originally Posted by cheeseplease
Okay, I'll run TMPEGEnc with 'Field order' switched to "top field first" now, as this was set to bottom field before.
I guess you mean 'top field first' when you said 'top frame first'?
By the way, what exactly is the difference between interlaced and non-interlaced video? I've never been really sure what interlacing is for and what it affects... can anyone explain it to me? (I guess this has nothing to do with the NTSC to PAL issue I deal with here, I'm just curious to know about it anyway).
Thank you! -
check here for all you ever wanted to know about interlace.
in summary:
in PC world: progressive good, interlace bad (and theoretically, yes this is the best way because you dont screw a frame up and fast action scenes dont look like blurry-vision with lines)
in TV land: progressive bad, interlace good (interlace uses less bandwidth [or at least in HDTV land, since with interlace, you have have up to 6 sub-channels within a channel stream if you use interlace], so you can do lots of other stuff. also, (i think) teletext and closed captioning rely on interlace [somebody please check on this, i'm pretty sure, but not sure enough]).
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum CapturingReplies: 33Last Post: 28th Nov 2013, 11:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 02:09 -
PAL-N VHS to ntsc dvd
By Paul99 in forum Video ConversionReplies: 17Last Post: 4th Apr 2011, 16:32 -
VCR is NTSC, but VHS is PAL
By joelson in forum MediaReplies: 1Last Post: 2nd Jun 2009, 08:21 -
Pal S-VHS to NTSC PC
By Jerry1964 in forum CapturingReplies: 14Last Post: 19th Aug 2008, 08:50
