  1. I hope someone can help me.....tried to play a dvd+r in my panasonic rv41...can't do...will not recognize it....will play in a cheap machine in my son's room...any help would be apprec..
    Onad
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Panasonic doesn't play well with DVD+R.
    Change the book type to DVD ROM, and it should play fine.
    If you don't know how to change the book type, do a search on bit setting. Also check the glossary (to the left), and DVDRW.org has some articles about it.
    Jul 2003
    michigan
    what program did you use to burn the dvd. on my panasonic the only burning program that will work is nero
