Newbie here, I want to make DVD's from my homevideos (DV) with acceptable quality and minimum time, I've experimented a lot and wonder if someone out there could comment on:
1 Using Ulead Moviefactory 2, capturing DV on-the-fly to MPG seem to give quite some quality loss, anyone having the same the same experiance?
2 Can MainConcept do the same thing but better?
3 Is DVTimeStamp the only solution to get the Date transfered into the DV Avi file (which means first doing a DV-AVI file = more time spent).
4 If transfering DV-AVI files to hard-desk, which is the best software? I've tried WinDV, DVIO and Vega.
5 Which is the best MPG-compression software? Have tried Ulead Moviefactory, MainConcept - very time consuming process.
Solution for burning of DVD
By pboong in forum Authoring (DVD)Replies: 19Last Post: 12th Nov 2010, 09:56 -
4:3 and 16:9 on same DVD - solution
By sergem1 in forum Authoring (DVD)Replies: 6Last Post: 15th Jan 2010, 02:03 -
DVD Storage Solution ?
By xobituaryx in forum MediaReplies: 2Last Post: 7th Feb 2009, 23:00 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
Need an easy all-in-one DV to DVD solution
By kyroha in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:16
