I am looking for a plugins into Video Editor of Ulead Media Studio v7.
I have Hollywood FX. Espesially I am looking for plugin which will be able to get signs into video. Internal tools is not perfect.
Results 1 to 11 of 11
What do you mean by signs? Traffic signs? Algebraic signs?
Hello. -
I found the Titles function in Video Studio 7 works perfectly. What problems are you having?
Hello. -
I am speaking about Ulead Media Studio and not Ulead Video Studio.
Title editor in UMS is quit poore. -
Originally Posted by CondorHello.
1. BorisFX
http://borisfx.com/company/ulead.php
2. Boris RED
http://www.borisfx.com/products/RED/
3. Boris Factory
http://www.ulead.com/partner/app/boris/factory.htm
4. Boris Graffiti
http://www.borisfx.com/products/GRAFFITI/
5. StageTools Moving Picture and Moving Chart
http://www.stagetools.com/tutor/UleadTutorial.htm
6. Profound Effects UseFul Things LE Starter Pak
http://www.ulead.com/partner/app/profound/profound_SP.htm
7. Profound Effects Useful Things LE Expansion Pak
http://www.ulead.com/partner/app/profound/profound_EP1.htm
8. SpiceMaster 2
http://www.pixelan.com/products/all.htm
9. Vixen Video Enhancer
http://www.xentrik.demon.co.uk/ViXen/vixen.html
10. Video Tools Server
http://www.videotools.net/index.php?rub=guides&htm=announceuleadvideoserverplugin.htm
11. VFXFlash-Factory
http://www.ulead.com/partner/app/vfxflash/vfxflash.htm
12. VFXMask
http://www.ulead.com/partner/app/vfx/vfx.htm
13. Stefan Burger Transitions
http://www.burgers-transition-site.de/
14. Doc Mordrid's Picture-in-Picture Setups
http://digitalvideo.8m.net/24pip.zip
15. Canopus VideoFX Transitions
http://www.canopus.us/US/products/videofx_transitions/pm_videofx_trans.asp
16. Adorage Magic
http://www.adorage.de/gb/index.html
The other may be that you are looking for features not available in MSPro. If the latter is the case, a few have been listed in other posts - most of them great, again depending on what you want to do. I would also recommend looking at (if "cool" effects are what you are looking for) Ulead Cool 3D studio. Probably the most overlooked tool out there... You can do some fantastic stuff with it, easily.
Again, tell us what you want to achieve, and we can be more helpful.Terje A. Bergesen -
Ok, I will try explain (with my english) what I want.
I have to say that Pinnacle Studio has also titling tool inside. It has better pressed effects to do very quickly titles which look very nice. The titles look more nice and you can use also shadow efffect with natural soft edge.
You can also apply more visual effect to your title.
I do not want to acccept solution to make titling in Pinacle Studio and generate AVI or BMP and import to UMS.
Is it more clear? -
You also say that you can have more visual effects - can you elaborate? What visual effects? 2D? 3D?
And don't worry about your english, you are doing fine.Terje A. Bergesen -
OK, I will try to prepare some picture which will describe what I want, what I like and what I am missing in UMS.
It could be better, than to write a lot of words to describe it.
Ulead DVD Video Studio 10 editor
By Steveold in forum AudioReplies: 1Last Post: 27th Apr 2011, 03:54 -
Ashampo burning studio 9 with video editor
By talx in forum EditingReplies: 3Last Post: 18th Mar 2011, 13:57 -
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 16:02 -
Slowing down video not Audio using Ulead Media Studio Pro 8
By engert100 in forum EditingReplies: 10Last Post: 25th Oct 2007, 15:17 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 11:14
