I have a new hyundai computer package with a dvd dual dvdrw-r dvd rewritable compact disc rewritable burner. I think from a website written on the tower "www.drvupdate.com" that it may be a BCE5216IM or similar if that helps. I have tried using cyberlink power producer and can make good copies, however they will only play in the computer and not in my 3 stand alone players. In the standalones the disc just keeps spinning and I get the message 'loading' I have tried using several different brands of blank dvds with the same result. I have searched this forum and found many similar issues but not anything the exact problem. Please help me as I have no idea what I am doing and you all seem to know exactly what you are talking about. thanks in advance,
Marni
Results 1 to 19 of 19
have you only tried cyberlink power producer ?
do you burn with it also ?
do you burn on dvd-r or dvd-rw? -
I don't think there is a definate answer to this. I have 2 standalone players that play some dvd's, but not others. Usually at least one of them plays the disk. In your case you may have 3 that are dodgy. I suggest getting down to the dvd dealers and try a dvd in all their machines. They won't mind if they think a sale will result.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
wow, what a quick response thanks guys!!
it is a dvd-r and I am using windows xp home edition, we have also tried in many friends players to no avail from cheap and nasties to the latest hi tech machines, I am now trying to burn a copy onusing nero smartstart so maybe that will be more successful -
You should try DVDSHRINK and DVD DECRYPTER both free programs and used by many people on this forum.
ok, so looks like nero smartstart isnt the answer - just tried to write a copy to the hd and it said burn failed and thats before I even put a blank in. will download the freeware mentioned above when I can connect that pc to the net only have this one organised at the moment
match your writer with your media, since you don't know what writer you have that could be very tricky. left column, dvd media or dvd writers for media choices once you find out what it is.
on one of the screens while TRYING to copy it says DVDRW IDE1004 0047 does this help?? been up all nite trying to work it out and now feeling a little bit frazzled
Not bothered by small problems...
Spend a night alone with a mosquito -
I have a friend with a BTC1004 and they are a bit picky with media , it seems happy with Ritek -Rs , It seemed to be Princo discs it strugled with.
It is definately worth getting a couple of DVD-RW or +RW to use till you are confident with your process . -
thanks iooi, have already been to that site. have also started to wonder if the + may be the way to go. last error report was something about the wrong perameters whatever they are
When you open / explore the copied dvd, do you only see an AUDIO_TS and VIDEO_TS folders with the dvd files iinside the VIDEO_TS folder?
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Okay, so I am using Nero burning rom and nero express 6 I can get everything to happen ok up until I press next and the next screen should have burn at the bottom right hand corner but there is no way to click on it it is there but not clickable if you know what I mean. when trying to put files into the video_ts folder I get an error message saying to change my cache preferences - what should I change them to and how do I actually put the files into the video_ts folder when I click on add??
you are all being so helpful but I am just not quite getting it,
thanks
Marni -
That sounds like you havent got enough space left on your h/d to store the files while they are being burned.Originally Posted by marni33tas
What size drives are you running ?
I would guess your windows partition has less the 4 gig to spare...This is asumming you are draging files from a disk as nero needs to cache them onto your h/d for faster/safer transfer.Not bothered by small problems...
oh iooi what a big technical response!!!
I believe I have a 40 gig hard drive if thats possible. and I think I only have one hard drive -
On your desktop, click on the My Computer...click once on the C drive so that it's highlighted...then look over to the left side of that window...it'll tell you the capacity of your hard drive and how much space is free.
Make sure your Recycle Bin is emptied out...and if you use Norton, you'll have to right click on your Recycle Bin and select Empty Norton Protected Files to get rid of anything you tried to delete. -
Actualy right click on the C drive and click properties.
If the file system of the HD is FAT32 it will have 4GB file limit
You need NTFS file system for DVD surely. iOOi 's technical point was a valid one. -
Unless its a .iso or someother disk image the file size and the fat32 limit isnt a problem as no 1 file is 4 gig+ the whole disk is YES but its made up of lots of small files.Originally Posted by andyp1
Quite possible yesI believe I have a 40 gig hard drive if thats possible. and I think I only have one hard drive
but how much free space does it have ? Is it partitioned into smaller drives ?
ie C, D, E etc...
Either of the methods mentioned will bring up a pie chart showning used and free space.Not bothered by small problems...
....or you could click start the run then type command, or cmd, Then in the dos windows type dir and hit enter.
"We were in barstow on the edge of the desert when the drugs began to take hold."
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 07:26 -
bad copies
By freewave in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2009, 02:43 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 22:29 -
DVD Plays fine on computer but is screwed up on standalones
By jalopy6 in forum Newbie / General discussionsReplies: 9Last Post: 14th Feb 2008, 09:17 -
Pioneer XV-DV313 will only play back up copies of dvd's, not originals?
By moults in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Aug 2007, 15:17
