    Nov 2003
    Brazil
    Hello, how are you all?
    Folks,
    If I have a VOB with the resolution of a NTSC CVD (352x480, NTSC, 29.97fps) is it to possible to convert to a CVD Mpeg2 without reenconding?
    Thank you very much,
    Andrew
    The bitrate is probably too high for a cvd so you must reencode(tmpgenc,cce,mainconcept) or transcode(rejig).
    If it isn't to high you could just try rename it to mpg and try burn as cvd...if it doesn't work demultiplex it to elemantary streams with tmpgenc and multiplex it back to a mpg, under file->mpeg tools in tmpgenc.
