if I see a m2v file, is this the same as a mpg file? What's the difference?
Thanks!!
pcexpress-guy
An m2v file is an mpeg2 file without audio. An mpg file usually has audio but there can be cases where they don't.
Do you remember when TMPGEnc needed an English patch? -
thanks!
is this true...
is a m2v always MPEG2 without audio?
is a .mpg file be either mpeg1 or mpeg2, mostly with audio, but sometimes can be without audio track.
is this the deal?pcexpress-guy -
These are Windows extensions and unfortunately not all applications are uniformed regarding their use. Normally m2v is an elementary stream and mpg is a system stream. But then, CCE adds mpv to the elementary stream. Others add mp2 for mpeg2 elementary video stream whereas audio tools understand mp2 as mpeg1 layer 2 audio. If you're not sure it's best to open the file with some MPEG utility (like the MPEG tools built into TMPGEnc) and will tell you what it is.
this may sound stupid, but why do they call a "system" file, one which has both audio & video streams (or more?) and an "elementary file" one which only has audio or video stream?
just curious.
thanks!pcexpress-guy
.m2v + .ac3 + .sub/.sub to .mpg
By stevie99 in forum Video ConversionReplies: 2Last Post: 9th Apr 2012, 04:01 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08 -
Authoring program? (m2v's/ac3's/mpg'sVOB's)
By RobAdam in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 07:53 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
