    Mar 2004
    ive made a dvd with tmpgenc.
    i accidently added a menu that i dont want
    is it possible for me to rip my dvd with dvdshrink, and re author cutting out the menu?
  2. Member Sakuya's Avatar
    Dec 2002
    Why not just re-author using TMPGEnc DVD Authoring, and select "No Menu" from that menu list? When you do that, the first thing that plays after inserting your DVD into your DVD player is your first title track.
    Mar 2004
    ive already burned it to disc though.....am i able to reauthor dvd folders in tmpgenc? i dont have the original .m2v file anymore
  4. Member steptoe's Avatar
    DVDShrink will do that easily, look in the guides on here, as I normally use DVDShrink for complete discs, and use DVD2One for movie rips only, so can't really tell you how to do it, but I know its pretty easy
    I've made that mistake with TMPGenc on more than one occasion, so know how easy it is !!
    Mar 2004
    lol, annoying isnt it? hmm well i have used dvdshrink for backup before....just looking at it now...
    i'd guess that i have to open my dvd, then click reauthor and just drag my movie file over to the left, leaving the menu folder where it is? then hit backup and re-burn? hope it is as simple as that
  6. Member daamon's Avatar
    Melbourne, Oz
    Hi kazz0817,
    I've not used it, so don't if it's exactly what you're after, but menuedit might be worth a look. It removes buttons from menus, so might remove whole menus?
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Mar 2004
    dvdshrink worked a treat, just re authored and only dragged my movie to the left side of shrink screen
