I recently received my wedding video on DVD. It is an exact copy of my VHS version. There is no menu, it just plays from the start. I would like to reauthor the dvd with menus and chapters. The DVD has .VOB files on it, what are the steps i need to take to do this? The DVD is broken up into 10 min segments, is there a way to make one file and break it up into chapters myself?
thanks
TMPGEnc DVD Author can also do it and is a bit easier to use than DVD-Lab although the menu creation process is somewhat limited in TMPGEnc DVD Author whereas DVD-Lab is more robust in that area.
But I find TMPGEnc DVD Author to be a breeze to use and setting chapters up in it is easier than any other program I've used.
You can import the VOB files directly into it and there is a free trail period when you first install it (I think it is either 2 or 4 weeks).
TMPGenc DVD Author and probably DVD-Lab will do exactly what you are looking for
Depending how far you want to get into DVD authoring, TMPGenc is a good start, DVD-Lab is much better but needs more effort to get good results
Try looking at TMPGenc DVDAuthor first though, I know it can easily set specific chapter points -
Not if you import the DVD files info either TMPGEnc DVD Author or DVD-Lab but beware other programs that might attempt to re-encode the video and/or audio.Originally Posted by kx5000
Wedding video
By kj1983 in forum EditingReplies: 12Last Post: 9th Oct 2008, 13:12 -
Help, I have too much Equipment Wedding Video
By HeidiSchold in forum Capturing and VCRReplies: 8Last Post: 20th Nov 2007, 14:17 -
I am going to be doing my first wedding on Video
By silentarts in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Nov 2007, 10:56 -
help need with my wedding video?
By ronaldo9_r9 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2007, 14:41 -
Wedding Video Editing
By producertravis in forum MacReplies: 11Last Post: 7th May 2007, 18:38
