I have tried different CD-RW media (Verbatin, TDK, Samsung), but it won't erase any CD-RW. If I put in a blank CD-RW, it writes fine, but when i try to erase it says its a 'Read-Only' disk. Happens on Nero, Roxio and other cd writing softwares.
I have tried with different firmwares(OEM, oficial and hacked) and its still the same problem.
Can some one please tell me why it reads a CD-RW disk as read-only ?
I have tried removing direct cd writing and disabling ASPI drivers also.
Thanks in Advance.
My father was have the same problem of you.
I have tested differents think, like of you, and it's didn't work too.
So we have test on CD-RW Verbatim UltraSpeed, and now it's OK."It's more difficult to destroy a prejudice than to disintegrate an atom" A. Eisntein -
there are 3 count em, 3 different slightly incompatible cd-rw media.. theres normal, hi-speed and ultra-speed.. the diff is in burn speeds
normal is 1x to 10x
hi-speed 8x to 24x
ultra-speed 16x to 60x
these speeds may be wrong but your drive has to be compatible with you media eg hi-speed drive can use normal & hi-speed media but NOT ultra-speed... This is a complete minefield. Also I think data integrity is best when the drive and media type match. Others feel free to fill in the factsCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
No dialogue, but other audio works fine
By MCPorche in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2012, 20:07 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 02:54 -
x264 audio won't play in GB-PVR or WMP, works fine in MPC
By bigshotceo in forum Software PlayingReplies: 2Last Post: 15th Apr 2008, 09:55 -
DVD plays fine on my TV but won't allow editing at all (11/15 deadline)
By Salva Veritate in forum Authoring (DVD)Replies: 14Last Post: 19th Nov 2007, 12:01 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 21:15
