Hi
I am using dvd shrink3.1 to back up dvd's
It usually takes an average of 2 hours to encode the dvd prior to burning
These encoded files are placed in my hard drive
My question is - Is there any way to go straight to a second burn via dvd shrink without having to go through the encoding process again?
Any ideas?
Once the encoded files are on your hard drive, you can make as many copies as you wish with your chosen burning program.
as OmegaSupreme said once the files are copied to your hard drive you can make as many copies as you want. OR if you've already deleted them just make another copy off of the dvdr you just burned.
Thanks Guys
I have been attempting to do this using Nero Express but it wont let me burn ie. use the "Burn" button -
Have you tried using AutoShrinkISO, its also free and works directly with DVDShrink to burn a DVD after its been processed
Strange about Nero though, but then again I don't use NeroExpress, I prefer to use Nero directly without all that wizard stuff -
If you're making a backup of your store-bought DVD, why need multiple copies ?
Only joking.
The burn button not enabling is due to some other problem. What I do is set everything up with Nero Express then swith to the full version at the last stage if I need multiple copies.If in doubt, Google it. -
Thanks for the suggestions guys I'll look at them all
Nero is a puzzle though. It should have been the 5 minute job -
Use ImgTools (the classic version) to create an ISO IMAGE file.
Basically you put your DVD files (the VOB, IFO, BUP files etc.) in a folder called "VIDEO_TS" and then you put that folder in (under) another folder which you can name whatever you want (such as the name of the movie) then ImgTools will create an ISO IMAGE file for you.
You can then burn this with DVD Decrypter.
In fact the newer versions of DVD Shrink allow you to create an ISO IMAGE file auto so you don't even have to use ImgTools
Can't beat DVD Decrypter for DVD burning and creating an ISO IMAGE file only takes a couple of minutes or so.
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
lite-on 165p6s, slow copy, good burning?
By troy512 in forum DVD & Blu-ray WritersReplies: 3Last Post: 23rd Oct 2007, 09:13 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12
