Subject closed due to lack of interest
Closed Thread
Results 1 to 18 of 18
I just use the WinXP Disk Defragmenter.
The free space is already free- the only way to squish the free space all together is to move the files that are scattered throughout the free space- that's what defragging is.
Or you could delete files. If you have a drive being used for nothing but capturing then don't have anything else on that drive. Capture, do whatever you're going to do with the captured files and delete them- no defragging required.
VoptXP v7 removed 7 gigs from my 120 gig comp. after the 30 day trail i cant use it anymore -=[
wish there was something as good as that prog - i used winxp first then that - that works so much better and has soooooooooooooooooooooooooooooooooo many extra features in it - i wish there was another freeware prog like it
In my opinion, the XP program works as good as any other. Some files can't be moved, but unless you have a whole lot of programs, it should move most of them to the 'bottom' of your drive and give you a large open space, at least as large as you have room left on the drive. The boot drive is the one that benefits most from defragging as there are many small files added and deleted often. I don't defrag my RAID0 video drive but maybe 3 or 4 times a year as it only has large files and rarely needs it.
I use Raxco PerfectDisk 6, used to use Norton, but I found PerfectDisk is faster and also has the option to defrag when you're not doing anything and also can defrag when a set limit is reached, so it will only do it when things start getting bad
Also, as you can do a boot-time defrag if you wish, you don't have the problem of the crap XP defrag stopping everytime something writes to a drive, or worrying if you've stopped all the tasks that may write to a drive, casuing it to restart once again
Plus the usual schedule option of doing a regular defrag at say 3am, every week, month, year
Defragging my entire system of 14 partitions across 3 hard drives !!, takes about 3-4 hours using maximum defrag and a free space defrag. Norton took forever to do that and then whinged it couldn't quite manage it due to not enough free space if things were getting tight
One hard drive is 120GB, with about 50GB used, and it flys through that, and its used constantly, with temp files (copying, deleting, moving, etc, etc), so has a lot of work to keep it nice and neat
If you use NTFS most defrag progs do about the same. Default winXP defrag - Diskkeeper-based actually does a better job pulling files together and "opening up" free space then Norton. I tried several disc util. before. Some time ago, as I recall, everyone who wanted to use a "better" tool was after Diskkeeper. Now, it is a part of WinXP... but search still continues...(?). Maybe a PerfectDisk is your solution. Keep in mind that your PC will never write files in a contiguous way (as per today's knowledge) so there is no point in constant realigning your files. As I said Diskkeeper (default dafrag in WinXP) is an excellent one. Large files like MPEG are written quite sequentially so if you avoid writing them to your OS part. (C
you won't even have a need to defrag them in the future. Have couple dedicated part. for large files and you will be amazed how nicely your files will be placed on them.
When Norton squishes it all up to the top, isn't this moving the files ? Your free space is free already.Originally Posted by lacywest
Anyway...
Let me get this straight...
You have 6 volumes - Are they all the 1 HD ?
Delete is not an option - Do you have other stuff on that partition you wish to keep ?If in doubt, Google it.
> If you dont know of a program that can do this ... you don't need to answer.
I never "need" to answer anything. But I did. If you don't like the answer, ignore it.
And I'd still like to know how you expect any program to move all your free space together without moving any files. But if you don't know then you don't need to answer.
QUESTION:
ANSWER:Originally Posted by lacywest
"I don't want to move my files but I used to be able to use a utility that, you know, moved my files..."Originally Posted by lacywest
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 07:47 -
FREE Copy of Total Defrag 2009
By MJA in forum Off topicReplies: 4Last Post: 9th Mar 2009, 20:07 -
How much free space needed for a defrag
By Rudyard in forum ComputerReplies: 5Last Post: 17th Apr 2008, 16:52 -
How to burn DVD without enough free space in C:
By LUCAS67 in forum Newbie / General discussionsReplies: 5Last Post: 26th Mar 2008, 14:30 -
Capture stop because no free space->corrupt avi
By RH+ in forum Capturing and VCRReplies: 3Last Post: 30th May 2007, 10:01
