I just finished ripping a DVD, using "DVD Decrypter". The problem is when I try to burn these files using DVD Decrypter, DVD Decrypter, will not except them. I would also like to put them on, a CD under 700MB. Can someone tell me, what I am doing wrong? Thanks in advance...
If you want a 700mb file you can burn to a CD you'll have to convert to Divx or Xvid. DVD Decrypter won't do that for you. You should use FairUse 0.4 or AutoGK for that. With your CPU the conversion is going to take a VERY long time.
If you ripped files with Decrypter then you ripped in file mode and DVD Decrypter will not burn them. Rip in ISO and Decrypter will burn the ISO.
I think you are doing everything wrong at the moment, but chin up, we'll get you there - just answer a few questions for me first.Originally Posted by enuff1
Some basic principles need to be understood before we can get anywhere.
Firstly, DVD Decrypter will only output back to DVD Directly if you rip the DVD in ISO Read mode. It can then output back to DVD by putting it into ISO Write mode.
Secondly, what makes you think a 4.7GB or 9.4GB DVD will fit on a 700MB CD ? It ain't gonna happen unless you do some modification to the DVD by reducing the quality of the output. Simple arithmetic should tell you this.
Thirdly, you need to make some choices. I gather from your post that you don't have a DVD burner, only a CD burner. That is not a problem. We can burn to CD but decisions need to be made, such as:
Do you wish to play it on a standalone DVD Player or just your computer ?
Will it be a hassle for you if we span the movie over two or three CDs and you have to change it halfway through ?
Try this;
Method 1:
Rip your DVD using my guide here.
Convert to XVCD using the guide here.
Method 2:
Do it The Eazy Way.
The Q word (Quality) is going to be the biggest deciding factor for you.If in doubt, Google it.
DVD Decrypter Problem
By WuPhilly in forum Newbie / General discussionsReplies: 14Last Post: 17th May 2008, 16:28 -
STRANGEST problem getting VOB errors on DVD Decrypter, IsoBuster, etc.
By Corellian Corvette in forum DVD RippingReplies: 7Last Post: 16th Feb 2008, 19:52 -
Problem with DVD Decrypter
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2007, 13:01 -
problem with DVDFab Decrypter
By cmonzon in forum DVD RippingReplies: 1Last Post: 4th Jul 2007, 20:18 -
Problem burning to Verbatim DVD+R DL with DVD Decrypter
By spyder67 in forum Authoring (DVD)Replies: 6Last Post: 14th May 2007, 17:49
