Results 1 to 21 of 21
  1. I was hoping someone could suggest a DVD player that I can use to play PAL DVDs on my NTSC TV. I tried to play PAL discs using a PS2 with a Gameshark region free disc and got at error that my TV is the wrong format. I guess I would need a player that does on-the-fly conversions. My local retailers include Walmart, Target, Sears, Best Buy, Circuit City, Ultimate Electronics, and CompUSA. Could someone suggest a DVD player that I might find at one of these retailers that will allow me to play PAL on NTSC TV. Thanks
  2. They are not the best DVD players out there, but the Apex units can play both NTSC and PAL.
  3. My local retailers include Walmart, Target, Sears, Best Buy, Circuit City, Ultimate Electronics, and CompUSA
    There are a lot of them in those stores. Try JVC and Philips.
  4. i recently did a review of the pioneer dv-270(s)
    https://www.videohelp.com/forum/viewtopic.php?t=215904&highlight=
    its an outstanding dvd player & only $70. it will also do only the fly conversions of pal->ntsc. i tried 2 pal dvdr's on it, they both worked fine.
    of course it wont play out of region discs, unless there is a region hack i dont know about..
  5. Member LisaB's Avatar
    phillips 727 is the best I've found. if they don't have it at your local walmart, then you can still order from walmart.com I think, and then return it to your local retailer if it doesn't work for you. The quality of the player and of the output (the 727 has 3:2 pulldown) is better than the 3 different apex players I have tried.
  6. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    The Cyberhome CH-DVD 500 is a great pick.
    Click HERE for simple remote control hacks to make it region free and copy protection free. PAL to NTSC is built-in no hack needed.
    The Cyberhome can be ordered for $79.95 directly from the CYBERHOME website.
    Another good source is the HK FLIX website. They carry region free PAL to NTSC DVD players by a number of companies including JVC, TOSHIBA, PIONEER and MALATA.
    The Cyberhome CH-DVD 500 is cheap but probably the best one for PAL to NTSC quality although it has a few quirks but hey you can't beat the price.
    - John "FulciLives" Coleman
  7. Banned
    Oct 2003
    Americas
    Friend of mine has bough Philips (see above) in Sam's Club for 50$. Excellent playback and the reason he bought it is same as yours (PAL on NTSC). I own JVC XVS 60 which I picked for the same reason (most JVC's convert PAL) some time ago. PAL playback is as good as NTSC.
  8. Member FulciLives's Avatar
    May 2003
    Many if not most Philips models here in the USA can be hacked by the user to make them region free but JVC is not so easy. The JVC will convert PAL to NTSC but for region free you are better off buying one pre-modified.
  9. After returning a few cheaper players for various reasons, I've been very happy with my Toshiba SD-4900.
    Toshiba SD-4900
  10. Banned
    Oct 2003
    Americas
    No doubt. JVC's are a bitch to crack. Never found a hack for mine. I use it for its impeccable playback. At the time I bought it it was top notch. Today you can buy a DVD player at the grocery store... for the price of 50 lbs of potatoes.
  11. :P hmmmm laver: 50lbs of potatoes hmmmm
    The electronic components of the power part adopted a lot of Rubycons.
  12. Toshiba SD4900: I just got one from buy.com for $69 including shipping. It is hackable to region free and does NTSC/PAL conversion.
  13. Member FulciLives's Avatar
    May 2003
    I've heard from some people that certain models of Toshiba DVD players just do not like DVD-R discs. In short they seem to be very picky. I don't know if it has to do with MEDIA or the way they were BURNED or what.
    You guys with the Toshiba 4900 ... ever test it with DVD-R discs?
    If so what brand of MEDIA and how did you burn it?
  14. My Philips DVD-727 was region free right out of the box.The Pal mode works perfect too.Set it to NTSC in the DVD menu to play Pal DVD's.By the way,the DVD-727 is suppose to read +R and +RW DVDs.I tried a Maxell +R and it doesn't work.I burned a couple and no go.The 727 doesn't list as playing -R DVDs but they work fine.Anyone know why the +R don't work on my 727?.Is it maybe it just doesn't like Maxell +R or +RW,maybe different brand of disk or am I suppose to use a different setting when burning.I use DVD Shrink 3.0 and Nero 6 ultra edition.
  15. Member nexus123's Avatar
    Feb 2004
    apex goes for around 42$ at walmart near me I love em
    "We were in barstow on the edge of the desert when the drugs began to take hold."
  16. Lite-On lvd-2002 will convert PAL to NTSC and vice versa. With a remote hack you can make it region free. I also own an apex ad-2600 that will also do the conversion.
    Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing--
  17. Originally Posted by Ripper64
    It's like you are telling the fairy tale. I have the 727 and I know at least 5 people who have the same player. Nobody had a problem with DVD+R or DVD+RW
  18. most of the apex line is great, as other people mentioned. I would do a dvd player search on the left, which I believe talks about Pal to NTSC. Actually, from what I remember, there are two flavors of this, the "yes, it will play PAL on NTSC" and "it will do a true conversion while playing on the NTSC".
  19. Originally Posted by lets
    I found out its my LG GSA -4040B that doesn't record +R disks very well.A lot of people are having the same problem.It will burn fine but not work in the DVD player.Thats what I found out.LG is suppose to be working on a firmware fix.I tried Maxell 4X +RW and it won't even burn.
  20. Originally Posted by FulciLives
    Sony 4XDVD-R and Sony 4XDVD+RW both work fine for me. Authored with TMPGEnc DVD Author, burn with Nero on a NEC2500A.
    I got my hands on some Imation dvd-r's burned off of a stand alone dvd recorder. I don't know the brand of the recorder. The dvd-r's will physically play back on my toshiba sd-4900, but sometimes the video will be choppy. While watching, you still hear the audio, but the picture freezes and studders for a quick second or so, as if what you are watching has some kind of strobe effect.
