i had posted a reply about a problem i have with a movie in CVCD, like another user, in the case can't be a solution, could be possible to convert a CVCD file to SVCD, this last is working gr8 for me.
Any help in this issue will be appreciate.
Thx in advance
CVCD is a spanish xVCD "format", very popular 4 years ago in spain.
It is mpeg 1, VBR and in a way it is like kwag's KVCD - without the huge GOP he use.
So, load it to virtualdub (virtualdub imports mpeg 1) and frameserve it to TMPGenc. Load the SVCD template and re-encode your CVCD to SVCD. That's all.
For eliminating some noise, add dynamic noise reduction. -
gr8..tyvm for your help, i'll try that, i'm still a newbie in in movies' world
i tried what you said, and TMPG said will took (minimun) 25 hours to encode it..is that normal?
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
