Hi all,
I have a problem here. I've been trying to back up some of my DVD's using DVDStripper with DVDShrink. The whole process goes fine without errors. but on several discs, while watching the movie, the movie will re-start while switching chapters. If I try to watch it again, it will sometimes restart, sometimes jump to another chapter, and sometimes play through like it should (often with a few pauses as if it is confused as to what to play).
Here is the process I'm using:
1) Strip with DVDStripper 0.3.0 (IfoEdit 0.97, DVDDecryptor 3.2.1.0)
2) Remove some trailors, extras, etc. as next step in DVDShrink (process the files with IfoEdit)
3) Open the output files with DVDShrink 3.1.7.5, remove some audio streams, etc. to further reduce the size to it's final size to fit on one disk.
4) Burn the disk with DVDShrink
When I use DVDShrink alone, I do not get this problem, so I am guessing the problem either lies in DVDStripper's commands to IfoEdit, of in IfoEdit itself.
Has anyone else had these problems?
Am I doing something wrong (I don't think so)?
Is there a better/easier way?
Please help. It's pretty annoying!
Thank You for the help!
Results 1 to 1 of 1
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 03:07 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42
