What is the best printable DVD-R which has the end results as in crisp bright images, but stil is reliable in burning and playing
Results 1 to 17 of 17
The choices are somewhat limited. Why not get a sample pack of three of four different kinds and decide what works best for you in your writer and printer.
Rick -
Very happy with the results i get with my Ritek 4x -r printables.
Not had any playback problems either.Not bothered by small problems...
Spend a night alone with a mosquito -
I'm loving the white inkjet printable 4x BeAll DVD-Rs right now. They print to the hub unlike the riteks & they actually work with my NEC 2500a unlike some G04s that I've come across.
jawgee -
If you can find some RICOHJPN Memorex they're probably the best ones out there for the price. Amazon had 100 spindles on sale not too long ago for $80
RICOHJPN are +R media...for the record.
I prefer Maxell printables...as good as their branded media. -
I'm having great success with Memorex DVD+R printables (after some major problems with a batch of Ritek G04's). I got 100 for $99.99 from amazon.com
Media Information
Region info N/A not a DVD-VIDEO
Media code/Mfr ID RITEKG04
Formatted Size Blank
Total Size 4.38GB(4.71GB)
Book Type DVD-R
Media type V2.2 DVD-R
Write Srategy Speed 4.0x 5540KBs
Media Id Code Speed Unknown
Current Drive Speed 4.0x 5540KBs
Default Rotation Control CLV
Linear Density 0.267um/bit
No of Layers 1Geronimo -
Where you can print right up to the 22m/m center hole.Originally Posted by dead_indian_walking
Unlike most disks where u have a 40 ish m/m area in the center of the disk that is unprintable.
I use Ritek 4x -r printables and im pleased with the results on my epson r200, but the print to the hub discs sound like a better way of doing them,
does anyone know where in the U.K they can be bought? -
As far as i'm aware no one has BeAll's for supply in the UK. I have asked SVP if they can source them but have had no feed back. There was a post about another brand of disks that appeared to have print ot hub capabilities but dont think there was ever a outcome on them...
Hi iooi,
i'v found some full face inkjet printables, they at www.stanleysonline.co.uk/product-3444.htm
but they are a little expensive, £75 for 50.
they are called MAME, iv never heard of them before.
i think ill stick with the ritek,s for now. -
oups, should have looked further down the page,
there are full face printables for £49 for 50 and £87 for 100,
called MPO, -
Thanks for the link Jinky
but like you at them prices i shall be stearing clear...
Not too clear on which format of disks they are either.
Have just emailed them to help clear up who makes the disk and format as a search (google) did not bring up any info on them.Not bothered by small problems...
Printable DVD Slipcover Templates
By nwo in forum MediaReplies: 0Last Post: 24th May 2010, 17:04 -
Printable Dual Layer DVD's
By ozab in forum MediaReplies: 3Last Post: 7th Oct 2009, 13:12 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 08:06 -
Help with printable DVD's
By stantheman1976 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Feb 2008, 09:47 -
Are there any Scratchproof printable dvd-r?
By Wile_E in forum MediaReplies: 8Last Post: 27th Aug 2007, 02:51
I use this, fine for me
