Hi All,
I've been using Nero for quite a while now. Never had any problems.
This morning I made two coasters so farIt is burning half of the
disk and erroring out. Appreciate if anybody can help me out to
resolve this issue. I've attached the log below:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
ahead WinASPI: File 'D:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/29/2003 11:37:36 PM
Nero Version: 5.5.10.50
Recorder: <SONY DVD RW DRU-510A> Version: 1.0b - HA 1 TA 1 - 5.5.10.50
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <LITEON DVD-ROM LTD163D>Version: GHR3 - HA 1 TA 0 - 5.5.10.50
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y120P0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1200JB-75CRA0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : LITEON DVD-ROM LTD163D atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DRU-510A atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 510MB (523260kB)
Free physical memory: 301MB (308972kB)
Memory in use : 40 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
10.4.2004
UDF/ISO compilation
8:47:15 AM #1 Phase 112 File dlgbrnst.cpp, Line 1655
DVD-Video files reallocation started
8:47:15 AM #2 Phase 114 File dlgbrnst.cpp, Line 1655
DVD-Video files reallocation completed (no file modified)
8:47:15 AM #3 Text 0 File Isodoc.cpp, Line 7589
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
8:47:15 AM #4 Phase 111 File dlgbrnst.cpp, Line 1655
DVD-Video files sorted
8:47:16 AM #5 Text 0 File Reader.cpp, Line 115
Reader running
8:47:16 AM #6 Text 0 File Writer.cpp, Line 125
Writer SONY DVD RW DRU-510A running
8:47:16 AM #7 ISO9660GEN -11 File geniso.cpp, Line 4571
First writeable address = 0 (0x00000000)
8:47:16 AM #8 ISO9660GEN -11 File geniso.cpp, Line 4571
8:47:16 AM #9 Text 0 File Burncd.cpp, Line 3744
Turn on Disc-At-Once, using DVD media
8:47:16 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2286432 (2286432) = #2286432/508:5.57
relocatable, CD pos for caching/writing not required/required, no patch infos
8:47:16 AM #11 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2286431 (508:05.56)
8:47:16 AM #12 Text 0 File DlgWaitCD.cpp, Line 234
Write in overburning mode: FALSE
8:47:16 AM #13 Text 0 File DlgWaitCD.cpp, Line 1693
Recorder: SONY DVD RW DRU-510A, Media type: DVD+R
Disc Manufacturer ID: RICOHJPN, Media Type ID: R01, Product revision number: 2
Disc Application Code: 0, Extended Information Indicators: 1
8:47:16 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder SONY DVD RW DRU-510A for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 387952640
8:47:16 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286432 blocks [SONY DVD RW DRU-510A ]
8:47:16 AM #16 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
8:47:16 AM #17 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
8:47:16 AM #18 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 4x (5,520 KB/s)
8:47:18 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
8:47:18 AM #20 Text 0 File Cdrdrv.cpp, Line 7931
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 01 52 49 43 4F 48 4A - 50 4E 52 30 31 02 38 23 ..RICOHJPNR01.8#
54 37 09 00 3C 67 00 AC - 62 16 18 0B 0B 0A 0B 01 T7..<g..b.......
19 1B 0B 0B 0E 0F 01 00 - 00 00 00 00 00 00 00 01 ................
8:47:18 AM #21 Text 0 File DVDPlusRW.cpp, Line 462
Start write address at LBA 0
DVD high compatibility mode: Yes
8:53:21 AM #22 SCSI -1135 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x023F0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x08
CDB Data: 0x2A 0x00 0x00 0x0D 0xC3 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x0D 0xBA 0x30 0x12
0x00 0x00 0x00 0x00 0x0C 0x08
8:53:21 AM #23 DVDR -1135 File Writer.cpp, Line 333
Write error
8:53:21 AM #24 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
8:53:21 AM #25 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
8:53:50 AM #26 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 4x (5,520 KB/s)
8:53:50 AM #27 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.60a, size=17232 bytes, created 8/27/2003 3:02:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 1:27:50 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I've already burnt about 40 DVDRs using the same media, and same
PC. I don't think media is a problem. Moreover, the media is from the
same pack of 50. -
Not every disc is created equally. What brand are they? Just because some burnt properly doesn't mean they all will.
DeleriumMDK- I am trying the disks from the same pack. So, I guess
they all must be from the same brand. It is Memorex 4X, made by
RICHOJPN.
richdvd - No, I haven't tried different software. I've been using Nero for neary an year now. Never had any problem. This happended suddenly.
I'll try another software. -
I am having the same problems, nero just stops and the same error is produced eachtime/ I have looked everywhere for a solution, many people have the problem but there has been no solutions anywhere, log also is displayed.
Shane
1502-4230-1279-0757-2957-5706
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 9:06:00 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 30/01/2003 7:37:36 AM
Nero Version: 5.5.10.56 (Nero Express)
Recorder: <TOSHIBA DVD-ROM SD-R6012>Version: 1733 - HA 0 TA 1 - 5.5.10.56
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
CD-ROM: <TOSHIBA DVD-ROM SD-R6012>Version: 1733 - HA 0 TA 1 - 5.5.10.56
DiskPeripheral : IC25N080ATMR04-0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TOSHIBA DVD-ROM SD-R6012 atapi Port 0 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 70254592 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 479MB (491036kB)
Free physical memory: 219MB (224684kB)
Memory in use : 54 %
Use Inquiry : 1
Wizard: On
18.4.2004
UDF/ISO compilation
3:29:17 PM #1 Phase 112 File dlgbrnst.cpp, Line 1655
3:29:17 PM #2 Phase 114 File dlgbrnst.cpp, Line 1655
3:29:17 PM #3 Text 0 File Isodoc.cpp, Line 7604
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
3:29:17 PM #4 Phase 111 File dlgbrnst.cpp, Line 1655
3:29:17 PM #5 Text 0 File Reader.cpp, Line 115
Reader running
3:29:17 PM #6 Text 0 File Writer.cpp, Line 125
Writer TOSHIBA DVD-ROM SD-R6012 running
3:29:18 PM #7 ISO9660GEN -11 File geniso.cpp, Line 4571
3:29:18 PM #8 ISO9660GEN -11 File geniso.cpp, Line 4571
3:29:18 PM #9 Text 0 File Burncd.cpp, Line 3773
3:29:18 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 672
original CD pos #0 + 1742928 (1742928) = #1742928/387:19.3
3:29:20 PM #11 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 1742927 (387:19.02)
3:29:20 PM #12 Text 0 File DlgWaitCD.cpp, Line 234
3:29:20 PM #13 Text 0 File DlgWaitCD.cpp, Line 1703
Recorder: TOSHIBA DVD-ROM SD-R6012, Media type: DVD-RW
Disc Manufacturer: OPTODI - SCK001
Disc Application Code: 64, Disc Physical Code: 214
3:29:20 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder TOSHIBA DVD-ROM SD-R6012 for write in cue-sheet-DAO
DAO infos:
MCN:
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -725143552
3:29:20 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 672
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1742928 blocks [TOSHIBA DVD-ROM SD-R6012]
3:29:20 PM #16 Phase 24 File dlgbrnst.cpp, Line 1655
3:29:20 PM #17 Phase 25 File dlgbrnst.cpp, Line 1655
3:29:20 PM #18 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 1x (1,380 KB/s)
3:29:20 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 1978
3:29:20 PM #20 Text 0 File DVDR.cpp, Line 1323
Recording mode: Sequential Recording Mode
3:29:20 PM #21 Text 0 File Mmc.cpp, Line 19546
Set BUFE: supported -> ON
3:29:20 PM #22 Text 0 File DVDR.cpp, Line 1437
3:29:20 PM #23 Text 0 File Cdrdrv.cpp, Line 7933
Book Type: DVD-RW (3), Part Version: 2
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
End Physical Sector Number of Data Area: 30000 h
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
3:46:57 PM #24 SCSI -1135 File Cdrdrv.cpp, Line 1447
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x028A0000
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x0A 0x17 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
3:46:57 PM #25 DVDR -1135 File Writer.cpp, Line 333
Write error
3:46:57 PM #26 Text 0 File ThreadedTransfer.cpp, Line 222
3:46:57 PM #27 Text 0 File ThreadedTransfer.cpp, Line 216
3:46:57 PM #28 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 1x (1,380 KB/s)
3:46:57 PM #29 Text 0 File Scsicmd.cpp, Line 406
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 9:06:00 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 9:02:00 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 5:00:00 AM (Adapter driver for rec)
Registry Keys:
Please can anybody help?
Nero 8 project, burn error... log file shown
By dvdking77 in forum Authoring (DVD)Replies: 4Last Post: 16th Dec 2010, 09:51 -
Get a log error trying to convert to dvd disc on Nero 7. Please help !
By seagulls in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2009, 16:00 -
Bose 3-2-1 region free hack doesnt work see attached keyorder on picture
By monsterag in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Jun 2008, 20:46 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Help. Nero error log
By R!ffraff in forum Newbie / General discussionsReplies: 7Last Post: 3rd Mar 2008, 15:22
