I know all about interlacing and progressive scan but there's something that's bugging me about PAL film DVD's.
PAL film DVD's are interlaced. But both the 'fields' that make up each interlaced frame on a DVD movie originate from the same frame of the film if you know what I mean and not like TV shows where the 2 fields that make up each frame are taken at a slightly different interval.
So what I want to know is even if a PAL film DVD is interlaced but like my explanation above says about the 2 interlaced fields being from the same frame and belonging together (you don't see any interlacing when you are converting them to DivX or whatever), could you tell a progressive scan DVD player to output as progressive regardless of the 'flag' at the start of the DVD saying it's interlaced? The way I see it all the horizontal lines from the film DVD could be sent to the TV to be displayed at the same time just as a progressive scan DVD does.
Thanks for any replies.
Results 1 to 1 of 1
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 07:01 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 13:52 -
PAL Camcorder with Progressive Scan Mode
By ropdoh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Jul 2007, 08:27 -
Interlace vs progressive DVD problem...
By main.dvd in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 09:53
