Major, since I started playing with ffmpegX, my entire goal has been to be able to build solid DVD's of various avi's, mpeg's, mov's, etc. The new FastDVD setting has DONE IT!!!! Perfectly, I might add!!! I made a DVD from the following: a Divx file, a, .mov and an mpeg1 that I had. I just used the fast DVD setting on each of them, and then used DVD2One's join feature, and PERFECTION!!! Just for kicks, I took the video and audio streams, and built a quick set of menus in Sizzle, and....PERFECTION!!!!
Easy, painless, fast, and it worked perfectly, no sync issues, no dropped frames, superb quality!!!
The solution is now here, people, and FastDVD is the answer!! I used to get mad over things that weren't quite right while ffmpegX was growing, but this is the payoff I was waiting for, if you need to take your files to DVD, use this tool, there is no need to spend hours fiddling with other stuff!!!!!
THANK YOU MAJOR!!!!!
Results 1 to 1 of 1
Fast and Best MKV to DVD Converter?
By Datson in forum Video ConversionReplies: 8Last Post: 22nd Jan 2012, 01:46 -
Please help find info about one brilliant Russian erotica studio
By constantinopolebuild in forum Off topicReplies: 4Last Post: 21st Jul 2008, 17:04 -
DVD Fast Playback
By Amirhosain in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2008, 12:58 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 20:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 21:43
