I have tried to burn two different movies from their cue sheets and the burn process is fine but when I try to play them in my vcd player it is in black in white and black lines scroll up the screen about every second, does anyone know what causes this or how to fix the problem?
Also the movie works fine on my other vcd player so do you think it is the cds that I am burning on because this has never happened to me before.
Sounds like a PAL-NTSC problem. Most newer players will convert on the fly but some won't, that's why it works fine on one but not the other.
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
