Does anyone else have this problem and what is the solution?
I recently purchased powervcr from www.gocyberlink.com. I installed it and it works well. However, now that powervcr is installed PowerDVD and all other players installed won't play DVDs.
I get the following errors in PowerDVD "unsupported format error 80040265" or "An object or name was not found 80040216". If I use InterActual player it says can't find DVD navigator?
If I reinstall PowerDVD it works fine BUT then PowerVCR won't playback anything it has recorded, which also means I can't showshift.
So, basically PowerDVD and PowerVCR can't both be installed and working at the same time.
Any one else have this problem? Solution?
Still waiting for support from Cyberlink.
Results 1 to 1 of 1
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Playing a h.264 aac MKV file with PowerDVD 7.3 nvidia purevideo installed
By maxpower2078 in forum Media Center PC / MediaCentersReplies: 6Last Post: 28th Jul 2008, 07:48 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Why doesn't the bloody seeking in PowerDVD work!?
By Sephiroth666 in forum Software PlayingReplies: 2Last Post: 14th Jan 2008, 18:55 -
What am doing wrong ? HD DVD using PowerDVD doesn't work
By NICEBUD in forum Software PlayingReplies: 12Last Post: 5th Nov 2007, 02:28
