Hi all,
I just authored a DVD using IFOedit's author capability (input was a m2v and ac3 file). I burned to DVD using Ulead MF2. The movie plays fine on my settop DVD player, but the player's time display keeps flashing between two times. At the beginning of the movie, the two times are very close to each other, but by the end, they are off by several minutes. Can anyone explain how to fix this problem?
I suspect IFOedit might be the problem based on a couple of other posts, but I don't know any other way to take take a video and audio stream file and burn them to DVD without re-encoding.
Zakkkkkman
Thanks Foo. I tried restream, but the problem still exists. I wonder if the problem is with IFOedit. Do you know of a way I can test this idea? Is there another tool that I can use to take my two stream files (audio and video) and create a VIDEO_TS folder with appropriate files?
I really would like to fix this problem because I am worried that if I play my DVD on another player, it might not play. Also, it is pretty anoying.Zakkkkkman -
For anyone interested...
I just tried using DVDAuthorgui in place of IfoEdit and the problem went away. I used the same stream files, so I think it is safe to say that the stream files were not the problem (unless DVDAuthorgui does some extra magic which IfoEdit does not do). DVDAuthorgui is a nice little program that doesn't seem to get much attention. It works for me anyway.
Thanks for all your suggestions.Zakkkkkman
Did WinFF have a display screen at one time?
By gastrof in forum Newbie / General discussionsReplies: 5Last Post: 18th Mar 2011, 02:38 -
why do some dvds not allow elapsed time/chapter to display?
By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 11:27 -
Running time display on video
By jonde42 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2008, 23:10 -
Display 3 subtitles at the same time on DVD
By Woogy in forum SubtitleReplies: 4Last Post: 29th Jul 2008, 10:28 -
Delete display of running time
By tonwark in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2008, 13:53
