  1. i'm recording some cartoons directly from TV to PC, but what is more important if i want to convert it ti Xvid ?
    i want atleast 6-7 episodes on 1 cd, so about 115MB for each episode
    so when i enter it into a bitrate calc, i get 340Kbit/s but there is no option on the resolution, so does the resolution matter??
    it should shouldnt it?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    resolution has no effect whatsoever on file size. It does have remarkable effect on quality. At 340kbps, I'd look at VCD resolution (352 X 288 for PAl or 352 X 240 for NTSC).
    If in doubt, Google it.
  3. Member rhegedus's Avatar
    on the jazz
    Plus, you don't gain anything from higher resolutions if the source is broadcast TV or VCR.
    Regards,
    Rob
  4. and how did you get those values? own experience or is there someway to calculate it?
    edit: and whats a good program to change the resolution? or does it also work with VirtualDub (thought i saw something like it)
  5. Member rhegedus's Avatar
    on the jazz
    They're the standard resolutions for VCDs - look at the TMPGEnc templates.
    Regards,
    Rob
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I found out by asking a question here ages ago. I got the answer that the bitrate I wanted to use would look crappy but got told to try it for myself. I did try it and the poster was right !
    As a general guide, quality is in the eye of the beerholder. Try a couple of 1 minute samples at different resolutions and different bitrates - you will soon find you own acceptable levels.
  7. Never, eer, EVER use 352x240 for avi. the aspect ratio is wrong. Use 320x240 if you are looking for vcd type res for avi.
    Nov 2003
    Houston, TX
    there's a good mix to find between high res and low bitrate and high bitrate and low res. i use nitrogen's bitcalc, after u've calculated the bitrate u need, u can also calculate a good resolution for the xvid files, around .250 bits per pixel is about right.
    hope this helps, josh
