  1. Back Again helpful lads more Episode disc help, Everythings over the last couple of months has been going sweet.
    But 13 of my Mpgs are fine but one says "Abnormal Termination or Incomplete File" How do I scan and Fix a file like this so that it will work.
    Im currently giving it a fast recompress in Vdub to try and fix it ?
    what would everyone suggest ?
    Cheers again lads
    try use tmpgenc and remultiplex them, under file->mpeg tools->simple multiplex and select your source mpg as both audio and video source and make a new mpg.
  3. Thanks Baldrick your a legend that worked as always.
    Dont suppose you could tell me how to
    joinh an jpg and wav file for a menu ?
    acutally if its a simple demultiplex which im trying now dont write it
    Thanks again mate
    Just encode it to a mpg with tmpgenc, choose the jpg as the video source, the wav as audio source and choose a dvd template and encode.
  5. what type of audio file should i use to keep the menu background file size down on the finalsed dvd instead of wav ?
    my current file takes up quite a few % of the DVD
