Ok so whos gonna help me?... I bought a Sony DCR-TRV14 MiniDV Digital Handycam a few months ago ... sure i can connect it straight to my VCR but wheres the fun in that?. The software that comes with it ,Imagemixer, doesnt support OSX I've tried imovie but nothing seems to see the Camera when i connect it. Any ideas?
Mark - Dublin, Ireland
Results 1 to 12 of 12
what sort of connections does this camera have?
USB? FireWire? Got anything like an analog-to-DV passthru? -
Although Apple doesn't list the TRV-14 as a compatible dv cam (http://www.apple.com/macosx/upgrade/camcorders.html), that doesn't necessarily mean that it isn't. Most, if not all, Sony dv cams have good compatibility with iMovie. I've been using my TRV-18 flawlessly for the past year.
Are you hooking the camera up via its firewire port? If not, make sure you do. -
I am connecting via USB ... i am a complete newbie ... so sorry if i seem a little slow. Neither Mac nor Sony list the TRV14 as mac compatible. But i am suure there has to be a way. I am looking at trying it true Virtual PC... if any one has any tips...great!.
Mark -
Originally Posted by dublin6th
I bought a Belkin cable and iMovie has had no problems "seeing" the cam. You need a "4-pin to 6-pin" firewire cable:
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Section_Id=1976&pcount...oduct_Id=62357
This SHOULD work. But, if you're still not sure if this will work, then I suggest you buy the cable from a store with an open-package return policy.
Then...
1. Hook up your cam by firewire.
2. Turn on your cam and set it to VCR mode.
3. Launch iMovie.
4. In iMovie, switch to camera mode (a switch below the main video window).
5. Start importing your video clips and enjoy editing fun.
Do NOT try Virtual PC for video editing. Performance will be poor. -
Thanks alot guys ... will run out and buy a firewire cable tomorrow! hope it works. I have another questions but i should start a new tread for it its about burning DVDs on a mac ... i've managed it ... but only with films under 4.7Gb.
Thanks Again
Mark -
it has been pretty heavily covered.......
rather than starting a new one just ask your ? in here real quick. -
Originally Posted by galactica
dublin6th, just check out Galactica's website which has the best info for DVD burning.
Let us know if if the firewire cable works or not. -
Cheers direwolf, that worked perfect ... picked up a belkin fire cable an hour ago and iMovie is perfect ... so other than iMovie what else is good for editing?
Mark -
You can also try Final Cut Express which has a steeper learning curve and more $.
Then there's Final Cut Pro which is very expensive but very thorough in features and much more $$$.
But if you have enough time (to learn) and money to spend on FCP, then I suggest you pick up a thorough teaching guide like:
http://www.chapters.indigo.ca/item.asp?N=35&R=1161076&act=A03&Item=978032118649&Sectio...DF04470CD52512
My friend read this book from cover to cover and taught himself FCP.
But, if all you're going to be editing is home movies, stick with iMovie. Its interface is quite easy to learn and it won't take up as much of your time trying to learn how to use it.
Have fun editing. I hope you have enough hard drive space. Imported DV footage takes up about 13GB per hour. -
I agree with the Final Cut Pro Book. I have it myself, and it's excellent...
I also like DVcreators.net Those are some really helpful turorials.... and the 2-CD package is great, but was created back in Final Cut Pro 2. but the concepts work just fine for the basics in FCP4
ffmegx won't install mac osx 10.6
By bloke666 in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2011, 11:34 -
Looking for a specific application for Mac OSX
By iwiiiiiiiiii in forum MacReplies: 6Last Post: 13th Jan 2011, 16:05 -
Unprotected (homemade) BD-R to ANYTHING editable - Mac OSX
By NJboss in forum Blu-ray RippingReplies: 0Last Post: 6th Feb 2010, 12:46 -
Install aegisub on Mac OSx
By Anicsi in forum MacReplies: 5Last Post: 11th Aug 2009, 07:26 -
DVD_RTAV, DV mode -RV, mac OSX
By anp in forum MacReplies: 2Last Post: 9th Jun 2007, 02:08
