  1. i am having a few problems during the burning process
    i am using burnatonce software or nero i go through the procedure to backup my dvd all is going well then its spits the dvd out after about 18 mins off burning can anyone help me with this problem. Would have anything to do with the dvd-rs that i am using thanks tom
  2. What dvdr's are you using ?
    What error message are you getting ?
  3. its burning ok to about 70 percent then it spits the dvd out i am using dvd shrink
    the dvd is the yellow topped datawrite dvd
