Will an AVerMedia DVD EZmaker card doing real time MPEG encoding give me as good (or virtually as good) a DVD as capturing in AVI and encoding with TMPGEnc?
I have a P4, 2.6 Ghz with 256 RAM and am capturing at 720x480.
No.Originally Posted by Georgeo57
If you really want to do real time MPEG-2 capture get a capture card that does it with a hardware encoder such as the Hauppauge WinTV PVR-250 for instance.
But even then you can only do a CBR or psydo VBR
Most movies are well over an hour so to get the best quality a 2-pass VBR encode is usually the best way to go and that is done with software from a captured AVI file for instance where the process doesn't have to work real time.
Real time ac3+ transcoder?
By andyhuk in forum AudioReplies: 1Last Post: 13th Jul 2011, 23:14 -
Low CPU Real time Video Encoding
By striker9 in forum Video ConversionReplies: 4Last Post: 27th May 2010, 11:54 -
Real time recording
By slaak in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 23:27 -
Real time video capturing
By Haopengyou in forum Capturing and VCRReplies: 3Last Post: 5th Aug 2009, 02:02 -
real time video on pc screen?
By bakerboy in forum Capturing and VCRReplies: 1Last Post: 11th Jun 2009, 10:36
