    Apr 2003
    When encoding my home videos from AVI to MPEG2 with TMPGEnc Plus, I am noticing that the start & end points are occasionally a bit off from what I selected in the Source Range option. Is this normal? Is there a better way to be more precise in selecting the start & end points of my videos? Thank You!
  2. A beter way indeed. Frameserve the video with avisynth would be an excellent way of getting precise cuts. Recommend you also install avisynthesizer , and VCF2AVS to add in the process. yte another way is frameserve from virtualdub. This process is all done with a gui and will be easier and quicker and produce the resukts you need.
  3. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Another vote for Avisynth
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
    Apr 2003
    I'll take a look at Avisynth. Thanks guys.
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    what is your source footage that you are using for input?
    I've done a lot of videos where I captured in multiple parts (to minimize the effects of dropped frames), and used the source range section in TMPG to make single-frame-level cuts (ie part #1 ends on frame 500. part 2 starts on frame 475. I set the source range for part 2 to frame #501 and encode) and I never had any problems with it drifiting or not starting / stopping on the frames I entered.
    source vids were usually full-D1, 29.97fps 720x480 avi files using the Huffyuv codec.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Apr 2003
    housepig -
    I'm doing it just like you. These are our family home videos that I am transferring in about 10 minute-segments to minimize dropped frames and audio sync problems. After a few more tries with TMPGEnc Plus, I am starting to think that the 2 or 3 problems I had with start & end points may have just been human error/my fault. I've always loved the quality of the TMPGEnc Plus encoding and now I think that the minimal problems I was having were my own fault. Thanks.
