i tryed converting a movie last nihgt picked the movie, picked "system (audio & video) picked the right file for the frames per sec. then i clicked start did the hole movie, then it was done i played the movie in the new *.mpg format and when it open up it said the movie was like 4 and a half hours longand there was NO sound but it plays the movie after the movie it was just a black screen for like 2 and a half hours? can anyone please tell me what i am doing wrong. and why there is no sound?? PLEASE
CERKILR
can u pleas give us more info to help u out better like what was the original file avi,mov and what was ur audio sorce and what software u use to play the mpeg file like that ok
i have some guesses try another player or rencode the file to mpeg and multiplex the audio and the mpeg file with bbmpeg the audio must be a mpeg-layer 2 audio file ok
sorry pinoy2201 this is the first time i have tryed to convert an avi to mpg and it didnt turn out to good. the original file was a *.avi and i wanted it to be a *.mpg so that i could burn and watch it in the dvd player, the audio source was in the movie do i have to convert it different? i used windows media player to play it back, what do you mena by multiplex the audio? and audio must be a mpeg-layer 2 audio file? is the audio in the movie not good enough? how come when the movie was done it said it was like 4 and a half hours long the first half was the movie and the second half was just blank, and the .mpg its self at the end was like almost 3 gigs???? thanks for your help pinoy2201
try rencode it again with TMPGEnc or panasonic mpeg encoder
and can u tell me what version if TMPGEnc u are useing
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
