Results 1 to 10 of 10
    Jul 2003
    Ok Guys, do I keep it as 2 discs, or try the big squeeze onto 1? This movie is 220min. and comes on 2 discs already, so I have a feeling that I'm going to have to LOTR EE this, and use 2 DVD-R's.
  2. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    I would image the 2 discs are DVD-9 which means you're asking should I backup (and compress) 18GB to 4.3. I think you'd suffer a significant degrading in quality. If it were me I'd back it up to two two DVD-Rs, which still would require compression and some degradation of quality.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    i would keep them on stone .. should last for a few million more years
  4. Thou shalt not steal
  5. i BACKED UP on 2 Discs worked great....
    Feb 2004
    And you don't have to worry about that pesky -R or +R issue.
    PB
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    yea -- as long as you avoid that crap sandstone format .... good solid granite is the way to go (green or black) ..
  8. I would agree. Sedimentary & Metamophic just don't cut it. Igneous is the only format for My Commandments!
  9. Originally Posted by BJ_M
    I heard the dark purple was good
  10. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Yeah! Dark Purple Rocks!! I think the latest version of DVD2TGPO give you the choice of Dark Purple and even maybe Burnt Siena or even the ever popular Raw Umber! I can't wait till it gets to Beta Stage!
    Have fun stormin' the castle!
    Rog
