I have an animation movie. When I author it using tmpgenc author, the output .VOB file always stopped in a specific frame of the movie. I found out that there is an anchor at the location where it stopped, as pointed out in the below figure.
Is there a way to remove this anchor to the last frame of the movie... or do you have any suggestion to make the movie being converted til the end?
Try setting that frame as the end point. The add the same file a 2nd time and set it as the start point.
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
TMPGEnc DVD Author 3 (Chapter Split In two)
By GeorgeD123 in forum Authoring (DVD)Replies: 2Last Post: 13th May 2010, 20:44 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Tmpgenc DVD Author 1.6 How Do I Move a Chapter One Page Over
By sneed in forum Authoring (DVD)Replies: 14Last Post: 3rd Nov 2007, 07:47
