  1. I was able to decrypt, encode and burn a VCD on my first attempt without any problems. However, on my second attempt, FlaskMPEG will only encode the FBI warning from the DVD and go no further. Any ideas or work arounds???
  2. You are probably loading up the wrong thing.
    I hope that you are either using DVD Decrypter or SmartRipper (on File Mode) to rip your DVDs.
    Take note of the vobset with longest length (usually main movie). Make sure that the relevant IFO file is copied over.
    Then in FlaskMPEG, load that IFO file.
    Regards.
    Michael Tam
    w: Morsels of Evidence
