    Dec 2002
    Okay, time for a question. I d/l the Mainconcept PVR. I was wondering how well it could capture to MPEG2 in realtime.
    Problem #1) It stays in 25 fps. I can't seem to get it to change anywhere.
    Problem # 2) I can't select 1/2D1. I get 352x240, 480x480, 704x480 and 720x480.
    The Captures look great, but are totally useless since they are non-standard. Anyone got a quick fix?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
    Mar 2003
    Uranus
    Look for registry settings ?
    Dec 2002
    Dam German program installs PAL by default. I changed it from PAL to NTSC but it didn't stick. Unintsall-re-install I guess.
    Dec 2002
    It works for VCD/SVCD/DVD, but not for custom MPEG. And it's an 2000+ on the CPU....ouch.
    No 1/2D1 really blows, my cable channels are analog. I don't see anyting in the INI files to let me change that. Too bad, everything else is pretty cool, including a built in cutter.
  5. I purchased this on the merits of their encoder and am very disappointed in the product, seems very buggy and unfinished almost like it was rushed out. Lets hope they release an update soon!!
    Mar 2003
    Uranus
    I just tried it too. I can't find anything in the registry
    that sets capture res.
