Well I just finished building my first system. I used a cheap modded case from Ebuyer Pic link (that's a bit off but its pretty similar) anyway it comes with a tempreture guage and 2 front tube LEDs. Has anyone connected anything like this before, I really have no clue?
That's a cool case. The temp sensor, not sure. But the tube lights usually plug into the PS connectors, the white 4 pin jobs. Or they might use the smaller fan plugs
Yeah it was the four pin adapter, found out myself but thanks for helping! Tenp guage was also just 4 pin but the numbers look tacky so i'm going to disconnect it.
My brother will be buying a case very similar to that - it's not got the temperature sensor on it, nor does it have the bubble lights.
What was your case like to build with? Is there anything you would like pass on to me, like does it come with the case fan?
Thanks in advance,
Cobra
iPad cases
By ryangarfield in forum Off topicReplies: 0Last Post: 25th Jun 2010, 13:55 -
what features do you want Windows 8 to have?
By deadrats in forum ComputerReplies: 3Last Post: 4th Feb 2010, 19:11 -
Converter with these 2 features...
By marioval in forum Video ConversionReplies: 4Last Post: 6th Nov 2009, 08:03 -
New Forum Features
By vhelp in forum FeedbackReplies: 2Last Post: 30th Mar 2008, 09:49 -
Features
By Jedi_Knight in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 29th May 2007, 18:29
