hi,
what are the best programs to convert avi to dvd format to play back on standard dvd player
i wonder which gives the best quality pictue & sound and keeps eveerything in sync
i have avi files that was capture from my camcorder which is not digital
hope someone can help
any advice would be a bonus
Hi UTDKING,
DVD format is MPEG2, see the blue "DVDR" link, top left of this page for the specs.
"best" is subjective, so someone's "best" might not be someone else's. However, the popular ones I regularly see on this site are (in no particular order):
TMPGEnc
Cinema Craft Encoder
Mainconcept MPEG Encoder
Canopus Procoder
There are others...
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I guess that depends on what you mean by "best". Here's what I use to get DVDs out of the video footage from my camcorder (Sony D8) :Originally Posted by UTDKING
WinDV (to transfer AVI from camcorder to computer)
VirtualDub and Panasonic DV codec (to edit the AVI if needed)
TMPGenc DVD source creator to encode AVI to MPEG2
TMPG DVD Author to author the DVD
NERO 6 to burn the DVD
All of this works fine for me, no problems, a/v sync is fine etc, so it's "best" for me becuse it's so easy to do, and costs so little. Possibly there are other combinations of tools that may yield "better" final results, I don't know; but since I'm a beginner at this sort of thing, ease of use is important to me. -
In my case, using Premiere to import DV for editing. Frameserve to Tmpgenc for conversion and finally Maestro for the menu.
There are other ways you can achieve the above, eg using Pinnacle Studio 9 which is a program that is able to import DV, edit and create a menu for burning onto a DVD. Athough from what I hear Studio 9 is pretty unstable at times.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
question about different ways to convert srt to sub/idx
By jimdagys in forum SubtitleReplies: 7Last Post: 15th May 2009, 01:12 -
any ways to convert from avi to asf very quickly?
By George2 in forum Newbie / General discussionsReplies: 34Last Post: 20th Apr 2009, 04:02 -
how to convert two avi files into dvd
By justmehere in forum Video ConversionReplies: 4Last Post: 22nd Jan 2009, 20:08 -
Convert AVI files to DVD
By gbc410 in forum Authoring (DVD)Replies: 4Last Post: 1st Aug 2007, 02:02
