  1. I am using Virtual Dub with logoaway v3.01 to remove the watermark of a movie I downlaoded, but my problem is this, when I save the file as an .avi using virtual dub the file size becomes incredibly big,the file size becomes a 9 gig video file when my original file was less than 150 mb, can anyone tell me a link to a guide that might fix this problem or maybe a way to just change the setting of virtual dub so my movie will be saved with the same or a similar size as the original video file????
    Thanks in advanced,
    LucasIga
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Your original file is compressed and VirtualDub is saving it to uncompressed RGB. Try using a different codec. I like the PicVideo MJPEG codec personally.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Before you save go to video>compression to choose a codec.
