    Nov 2001
    Dallas, TX
    i downloaded nero b/c i read in the "how to" section that making photo albums is easy. i followed all the directions on this site and it's not working. i also searched the forum archives and did not find an answer to this question, so i feel it's appropriate. i have tried 3 different ways to burn a photo album using nero and none will play in my pioneer dv-333(which i understand will play "anything" according to this site-that's why i bought it!) but it's not playing these discs. when i put the disc in and choose "display", it says 1/1 tracks 0.04 for the time. is there something i am not doing? it had 75 pictures on it at 5 seconds each. i tried "inifinite" time per pic, DAO and TAO and none of the 3 discs play. has anyone successfully made a photo album w/nero? i don't want to buy software or change pic sizes, etc. i just want to drag, drop, and burn. can it be that simple? thanks for any help!
    Jan 2001
    Buenos Aires, CF, Argentina
    The problem with Nero and the 333 (which I own) is that if you put infinite time on menus or images, the disc will not work.
    I can recommend you:
    1) No infinite times. Put 30 or 40 seconds
    2) Use Win On CD 3.7 or 3.8 on Photo Albums. They work great.
    And don't worry, your player it is one of the best and plays anything (the only problem is this one with nero)
    Jul 2001
    Hmmm... I never had any problems using Nero when producing photo album... Maybe it's the format that Nero is using...
  4. I have created VCD's from jpg files using nero but I have to burn to CDRW media. I have only found one brand of CDR media that works well. It is COMPusa gold colored 50 to a pack for $19.95/pack.
  5. I used this website instructions to create photo album and burned it with 5.5.6.4 on CDRW worked fine. Took long time to recognize by DVD but was fine otherwise
