Hi guys,
I tried twice using movie only option and removing the extra audio and got diffrent results but yet both are signifigantly under 4.3 one is 2.93 and the other is 2.98. In both cases I put the slider to 4.3.
Any suggestions
VCD4ME
Results 1 to 10 of 10
We were all NEWBIES once and the only stupid question is the one that's not asked?
Don't mean to sound funny about this, but, has the thought occurred to you that maybe it is already at the limit of its quality/resolution?
Perhaps it doesn't require any more space.
There are pressed dvds like that, too, in other words, the video on them doesn't have to fit the capacity of the disc in order to be complete.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
Other problems include the fact that IC has problems with dvd structure if you delete items. It is more than likely that IC isn't compensating for the additional space when deleting objects. Plus IC is notorious with sizing issues.
Blah, blah, blah -
I use version 7 with the three updates and InstantCopySettings v1.4.1 tweak Instantcopy, works a treat.
I've tried many programs but found this to be the best for me, excellent quality and allows the most features to customise the way you shrink your DVD.
A while ago I came across an article some guy wrote about the way Instantcopy re-encodes the data. he used a $15000 program to compare the actual MPEG data, he also found the bitrate followed very close to the original just a little lower except the highest peaks were the same and the lowest points didnt go any lower than the origional.
I'll try to find this article if anyone is interested as I was impressed by his findings.
Have you gone along the CCE method?
If so, how do those results compare?
Also, did you have any sizing issues with IC?TheGame7 - "I am 'The Game' because I am that damn good!" -
Try the hidden settings program
for IC7/IC8 at http://www.mrbass.org/instantcopy/ -
Thanks guys,
Sorry I haven't posted sooner I've been dealing with an extreme jerk on ebay.
Anyways Sorry I didn't stype this before ....I am using IC8 (build 0270)and hidden settings 1.4.3
Painkiller - the video is at 5.3 on the original dvd and I can't even get it to 4.3
Signed
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
The best advice your going to get:Stop useing that POS instantcopy! Its just a big waste of time with its awful sizeing issues combined with the insane processing time.DVD2One,DVDshrink,DVDxCopy,etc Anything is better.Originally Posted by vcd4me
Personally i use DVD2One.Its a Solid and well made program that processes fast and delivers the full 4.36GB filesize everytime.Its also easy to use with no hassels whatsoever and delivers excellent quality. -
star warrior,
I have dvdxcopy and I don't really like it.
The only time I have the problem with not fillling the disc is in movie only . the times when I do the user defined it fills the disc.
Signed
EdWe were all NEWBIES once and the only stupid question is the one that's not asked?
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 10:49 -
windows 7 64bit and secondary data 3TB HDD not visible in full capacity
By deejay.2001 in forum ComputerReplies: 14Last Post: 21st Jun 2011, 16:08 -
Optical Disc Storage Capacity
By Frank-0-Video in forum MediaReplies: 2Last Post: 8th Jun 2011, 12:57 -
What is the LARGEST capacity disc I can buy?
By sarainelkins in forum MediaReplies: 17Last Post: 21st Mar 2011, 00:43 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26
