Is it possible to make a still shot Jpg from a DVD, I know when you try print screen it just comes out black.. But it is a DVDR ive made from a camcorder video and is not any copyrighted movie, so is there a way of doing please????
DVD region settings are a joke, I can't believe how stupid people are falling for it
If you are using Windows Media Player, try turning off Overlay mode in the options (Tools, Options, Perfomance tab, Advanced buttom, then uncheck "Use Overlays"). A second option (if you are not using WMP9 to display the video) would be to turn down video hardware acceleration in Windows until you get a good capture. You could also try SnagIt from Techsmith. Download the evaluation version first, to make sure it is suitable for your needs.
Or use Media Player Classic, under file->save image.
Another work around with media player is to open another file first and let it play. Then open the one you want to capture from and print screen all you want. The overlay will only be used on the other clip, so you won't have problems capturing from the 2nd one.
Legal: Old defunct newspaper shot
By zoobie in forum Newbie / General discussionsReplies: 7Last Post: 23rd Dec 2010, 06:22 -
16:9 shot, but 4:3 in DVD Architect.
By zovx in forum Authoring (DVD)Replies: 25Last Post: 14th Oct 2010, 09:46 -
automatic shot by shot video cutter
By monks19 in forum EditingReplies: 4Last Post: 26th Oct 2009, 20:17 -
What shot is this called?
By Chippy in forum Newbie / General discussionsReplies: 4Last Post: 18th Apr 2009, 00:47 -
Shot in HD - burn to standard DVD
By revlis in forum Video ConversionReplies: 1Last Post: 6th May 2008, 22:56
