I need to convert my NTSC dvd files to PAL so I can watch them on my stand alone. The files are DVD-r files (ifos and Vobs), I don't want to convert them to mpegs or avi first and convert them back.
Does anyone know of software that will allow me to do this? I have tried TMPG and some other converters but they don't accept these types of files. Or is there a program that can extract M2V video and mpeg audio files while converting to PAL?
Results 1 to 13 of 13
Originally Posted by steely_charm
You want to create a D2V project file and you want to DEMUX (not DECODE) the audio.
As for NTSC to PAL conversion here is a start:
http://www.geocities.com/xesdeeni2001/StandardsConversion/
Good Luck !!!
Please note that to use Xesdeeni's SmoothDeinterlacer plug-in (which is needed if your NTSC source is INTERLACED) you will have to use AviSynth version 2.08 as newer versions don't work with that particular plug-in (at least in my experience).
I have been told that if you add a region 0 it should play. What program can I use to do this?
Are you in UK . I ask this because pretty much every thing in Uk handles NTSC perfectly well and does not need to be converted to PAL.
I am in the uk.
Both my stand alone and my girlfirends become very jumpy when playing a NTSC dvd. But fine when playing a PAL. Other stand alones play it fine ie. my parents new sony.
I am pretty sure it is the NTSC format, but any other ideas are welcome. On my stand alone it becomes jumpy after about 2/3rds of the film, and my girlsfriends is jumpy straight away.
Any how-to's on the regioning? -
Any DVD-R you make will be region free . The only time you need a region free player is if you want to play an original non-region 2 disc in it.
I think you may have a media or DVD-R>Player compatability issue here.
I play NTSC in a PS2 , a Standalone Philips DVD Recorder , a cheap play anything Player , and Ive tried on a few friends various assortment of players with no issues.
I would try a different make of DVD-R or +R first , Ive read about NTSC to Pal conversions and It looks awful complicated to get it right.
I don't know what DVD Players apart from the Sony you have ( Top Brand or just cheapo players) . The cheap players tend to play most things whilst the 'dearer' players tend to be picky about what they play.
If you know someone with a cheaper or unknown brand maybe you could try your disc in that. -
What stand alone DVD player do you have? Make, model etc....
Regards,
Rob -
It is a grundig GDV520 finearts.
The problem only appears on NTSC films. 25fps films work fine.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
