I cant find a tool to convert my avi video file to mpeg as I want to watch it on my computer but it doesnt support avi.
I tried avi2mpg1 tool but its a command line tool and too complicated for me. What freeware tool is available to do this?
If your computer can't play avi's, then somethings busted. Avi's are native to all microsoft OS's. You'll need to download a codecs pack - I recommend 'The Codecs' pack at:
http://www.theorica.tk
Mpeg is a 'Final' format primarily designed for playing on hardware players, not needed if you're just playing it on your computer. Best freeware tool for avi to mpeg most definitely TMPGEnc - professional quality. Available here:
http://www.tmpgenc.net -
Luke 23 -don't do it like that.
Codec packs are not he way to go they can cause conflicts.
There are many different types of AVI file ( DivX Xvid etc) I don't know what type you have so you need a programme to identify what you have.
Go get Gspot or AVICodec either of these will identify what sort of AVAI you have.
If it is Divx go get the latest Divx codec , If it is Xvid go get the Xvid codec , all these things are available free via the tools section on this site.
If your clip plays then carry on using your PC and if you come across another in the future that wont play get the codec for that etc.
What you will find is that with vary few additional codecs you can play most types of AVI out there.
Codec Packs can cause as many problems as they solve.
Once you gat the AVI to play in media player or whatever then you can start thinking about 'encoding the AVI to Mpeg . TMPGenc is probably the easiest for a newbie and there are many good easy guides for it.
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 20:56 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
MPEG1 -> MP3 conversion possible in DOS?
By Figge in forum Video ConversionReplies: 3Last Post: 25th Mar 2009, 09:05 -
MPEG1 to H.264 conversion
By sarvagya in forum Video ConversionReplies: 5Last Post: 14th Dec 2007, 04:25 -
mpeg1 to mpeg2 conversion picture quality will improve or the same?
By live4fun in forum Video ConversionReplies: 9Last Post: 9th Jul 2007, 09:27
