  1. I just got a movie from a friend of mine and it has a really annoying watermark written at the bottom of the movie wich I don't know how. I know
    how to remove it using tmpgenc but I just want the movie to stay in the same size range as the original 1, can anyone help me???
    canada
    A better way is to load the file in virtualdubmod and use logoaway filter and frameserve to tmpgenc.
  3. Member steptoe's Avatar
    Just guessing, but if that movie has a 'watermark' I'm assuming that its there for a reason :
    Preview copy only
    pre-release copy only
    Rental preview only
    Timecode (definately preview movie)
    Unless its been recorded off the TV, but if its only at the bottom, then I'd suggest that movie is a pirate
    I may be wrong, but ................
    And yes, the only way I know of, is by using the previous posts suggestion. It does work, as I've played about with that just for the fun of it
    Its simple to use, but read the instructions that come with the plug-in, you do need to follow certain steps, takes about 5 minutes to set-up
