I want to convert an avi file to vcd and i am using nero and i was woundering when it says endocding dose that mean it is changeing the avi file over to vcd so that i can watch it on my dvd player.
Thanx
It's converting the mpeg-4 avi into mpeg-1 video, as well as creating the proper VCD file structure that your DVD player will recognize, assuming your player is VCD capable.
It does , but using nero to encode is not reall a good way to do it.
You should be looking to use something like TMPGenc for encoding the AVI to Mpeg1 and then use Nero to create a VCD using the Mpeg1 you created.
I think you need to do a bit of reading . Try here ..............
https://www.videohelp.com/forum/userguides/94288.php -
If in doubt, Google it.
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
Converting PAL to NTSC error Attempted to read or write protected memory.
By VHSonDVD in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 26th Oct 2009, 08:15 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Converting a DVD to be read on my computer
By jwajkb in forum DVD RippingReplies: 7Last Post: 16th Nov 2007, 17:25
