I normally use DVD+R but i decided to try -R cause they are cheaper... I went and ripped a DVD at 4X and the video skipped alot.... If i burn it at 1X it burns less but on some dvd players it choppy and skips a bit... how can I stop it from skipping or is it the DVD-R cds?
Sounds like you bought cheap discs.
For the most part, a high quality DVD+R and DVD-R discs will be the same.
The problem is, many retailers stock cheap brands of DVD-R discs. Like KHyper, and "store" brand names. Which are OEM'd by Princo, Optodisc, and low grade CMC.
With DVD-R you want to stick with brand name stuff, like Fuji, TDK, Maxell, Verbatim and so on. These are some of the better stuff.
Memorex DVD-R is not as good as the Memorex DVD+R. -
Which is the best online store to buy dvds that work from? and they ship to canada?
please help me out and give me a store with the cheapest prices and point me in the right direction in which one to get... my burner is a Sony DRU-530A. -
I never had a problem with my sony dru500x and ritek dvd-r's 1x-4x from www.shop4tech.com
Check the DVD Writer's comment section on the left, see what others say about the Sony 530.
The 530 is a rebadged Optowrite, so check comments for that writer too.
Besides shop4tech, there's also www.rima.com , www.supermediastore.com , www.meritline.com . 1000's more, but those seem to be the biggest/most popular.
None that much better/cheaper than others, everyone has their favorite pick.
I choose Rima, and Prodisc 4x DVD-R media, and Taiyo Yuden 4x DVD-R media. Before you buy 100 packs, check the DVD Media results (also on the left), and try out a few sample packs from your vendor of choice to see what works best for you. -
Canadian media thread.Originally Posted by simplexx"Art is making something out of nothing and selling it." - Frank Zappa
In Hong Kong, branded + and - media are the same price. However, there are more unbranded - media available with cheaper price.
VLC looks washed out compared to WMP
By stringcheesy in forum Software PlayingReplies: 3Last Post: 12th Sep 2011, 00:27 -
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 09:11 -
X264 DVD rips look very pixelated compared to MPEG-2 i.e. DVDSrink
By Z.Sath in forum Newbie / General discussionsReplies: 19Last Post: 28th Feb 2009, 23:52 -
DVD-rip compared to VHS
By Digiface in forum MediaReplies: 7Last Post: 4th Aug 2008, 13:34 -
DVDlab Compared with TDA
By loster in forum Authoring (DVD)Replies: 7Last Post: 30th Dec 2007, 20:34
