could anyone recommend me a reliable capture card for MPEG 1 & 2 that will do both NTSC and PAL, either pci or usb.. and must be below $200.
Also it must be compatible with use of Ulead Video Studio 7 and Windows XP.
Also i would like one that does not drop frames or quallity, and when it is put onto the dvd i would like it to be exact same quallity as the tape.
Thanks for your help in advance, Donald.
Results 1 to 1 of 1
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 23:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 23:10 -
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 03:41 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 11:28
